Slow Toilet/Tub/Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2008, 12:27 PM   #1
I already posted this before but can't find it.
I have a second floor bathroom that I remodeled with a new toilet, vanity and sink. I replaced the drain pipes for the tub and the sink since they were both rotted when we bought the house. My problem is the tub drains very, VERY slowly and the toilet isn't as powerful as I would like. It seems to have a very weak flush and can't handle any more then a very small amount of material. I think the venting system is my problem but I would like to post an image of my setup and see what some of you think. Also let me know what my possible solution would be.
Thanks.
Slow Toilet/Tub/Sink-bathroom.jpg
Weekend Warrior DIY is offline   Reply With Quote
Old 10-24-2008, 01:02 PM   #2
DIY'r
ScottR's Avatar
Poor shower drainage/toilet flushing slow
ScottR is offline   Reply With Quote
Old 10-24-2008, 01:49 PM   #3
Alright that's the link to the old post.
If anyone has new ideas, please let me know. I'm tired of taking showers in standing water. It worked ok for a while in the beginning but not so much now.
Old 10-24-2008, 07:35 PM   #4
I think your problem is venting, or actually, lack of. Click on the link below for an idea of what yourdrain piping and venting should look like.
http://www.hometips.com/hyhw/plumbing/74drain.html
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-28-2008, 08:10 AM   #5
I thought my problem might be venting but more so I'm thinking it has to do with the way the tub and sink are piped into the main sewer line. The tub fills up within only a few minutes of showering. The toilet seems to flush ok but def. not great. When someone flushes the toilet I can hear the water running down the vertical pipe in the downstairs bathroom but it def. doesn't do much in the shower. I'm getting very fed up with this. I think a call to the plumber is in order.
On a good note I did replace my pressure tank and now I have very nice pressure and no disruption between hot and cold water like I did before. I only hope that this isn't something I need to tackle every few years since I did find a lot of setiment and debris in the valve works and hose from the well.
So one issue down, one to go.
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 03:00 PM
Poor shower drainage/toilet flushing slow Weekend Warrior DIY Plumbing 10 10-10-2008 07:31 AM
Trying to fix the server... Please post here if you notice slow pageloads! Nathan General DIY Discussions 5 08-07-2008 11:45 PM
Slow leak from shut off valve Topdog Plumbing 12 06-05-2008 12:02 AM
stool flushes to slow dtarbet Plumbing 3 12-28-2007 06:46 PM
