Slow Toilet Draining In Mobile Home - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2010, 07:56 PM   #1
Solutions (handyman)
Rewards Points: 364
Slow toilet draining in mobile home
I am doing a reno job in a mobile home and one issue is that the toilet flush is quite slow. I had to remove some on the flooring around the toilet and saw that the drain from the toilet to the stack and beyond is actually on an up hill grade.I can't move it much and the best I can do is to get it roughly level. Would this help or might there be another issue? Do all toilets flush with the same or similar velosity? Best guess and/or suggestions are welcome.
Mark Harvey is offline   Reply With Quote
Old 04-02-2010, 08:13 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Having it flat is better than opposite assuming it isn't going up and down and up and down further on down the line, but there are no guarantees on a flat drain line.
It would be worth your while to correct the grade issue. 1/4" per foot inside the building.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Mark Harvey (04-03-2010)
Old 04-03-2010, 10:53 AM   #3
Rewards Points: 352
It had the correct pitch when originally installed. First thing I would do is find out why it is reversed pitched. The solution might become obvious then
plumberinlaw is offline   Reply With Quote
Old 04-03-2010, 11:19 AM   #4
Rewards Points: 1,016
Agreed, this was my first thought. The sections that are inside the construction or inside the frame should have the proper pitch - if not, why not? Is the trailer itself level? Are you sure it's not the toilet - dump a bucket of water in it and see how it drains.
I've worked on several mobile homes (maintained them as rental units). Plumbing is usually pretty reliable if the trailer is level and well connected to the sewer connection. With one notable exception for those with front kitchens - the line from the sink has a long run with minimal drop - and gets clogged with grease over the years.
Old 04-03-2010, 12:39 PM   #5
Doing it myself
Alan's Avatar
Older mobile homes not so much.....
Journeyman Plumber
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
slow flushing toilet jlandry Plumbing 3 02-02-2009 01:42 PM
Slow Toilet GKMOORE Plumbing 4 01-31-2009 05:54 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 03:00 PM
