Slow Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2009, 10:02 AM   #1
Slow Toilet
Have A Toilet That drains When Flushed; No whoosh! Have Tried To Snake Out And Have Even Removed To Check And Clean Out. Have Heard About Vacuum Or Lack There Of. Is This A Main Stack Blocked Or An Air Damn Somewhere In The Toilet Itself. If In The Toilet, where? Older Model With Plenty Of Tank Capacity. I've Tried Everything I Can Think Of.
GKMOORE is offline   Reply With Quote
Old 01-31-2009, 10:11 AM   #2
If you can see the jet hole in the bottom of the bowl check to see if it is stopped up. If it is clean it out. a short screw driver works well. If it is stopped up the stoppage will likely be hard as a rock. Be patient and chip away to get it out. Also, use a coat hanger clean out all the holes in the underside of the rim. This should help your problem. If not, then move on to checking the drain lines and/or vent pipes for blockages.
jporter5333 is offline   Reply With Quote
Old 01-31-2009, 11:13 AM   #3
No Toilet Whoosh
Thank You For The Quick Response. Found This Hole In Second Bath Toilet, But Not The Problem Child. Looked Underneath With A Mirror; Nothing. Did, However, See Some Calcium Build Up And May Try A Dose Of C.l.r.
Old 01-31-2009, 12:22 PM   #4
Replace the toilet with one of those toilet to go box. It's under $100 and that will fix the problem. Sounds like the toilet is bad.
John McCabe is offline   Reply With Quote
Old 01-31-2009, 05:54 PM   #5
Rewards Points: 1,494
Is there another bathroom directly above or below the problem toilet? If so observe that toilet as someone flushes the problem toilet. Should the water level in the bowl bounce noticeably, you may have a venting blockage in your drain piping system.
Fluidmaster - Slow filling toilet ronniecr Plumbing 12 06-18-2014 06:49 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 03:00 PM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
