Slow Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 07:38 AM   #1
Slow shower drain
Over months have used Liquid Plumbr or Lime-Away
to fix slowness.
Strange thing: after shower, allow water to drain,
then turn on hot water: goes down immediately
and never backs up. Problem comes back next day.
anotherpelican is offline   Reply With Quote
Old 09-03-2012, 07:49 AM   #2
Rewards Points: 40
I would recommend you stop using the chemical approach, it can be hard on your pipes, can be dangerous and it doesn't seem to be helping anyway. Start with the basics and check for a hair blockage in the trap.
daveb1 is offline   Reply With Quote
Old 09-03-2012, 07:55 AM   #3
DIY staff
Rewards Points: 7,174
Get yourself a small crank style drain auger----shower drains get sticky with soap scum and grab hair----rod it well.
And listen too Daveb1---no chemicals----they don't work well---can ruin your pipes--and present a real hazard to a plumber ---that stuff burns.
Old 09-03-2012, 11:08 AM   #4
In a little over my head
Rewards Points: 706
Every homeowner should own a small drain snake, IMO. Pulling that ball of hair out is strangely satisfying. Not to mention that $15 snake saving you $100 every time you use it.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
oh'mike (09-03-2012)
Old 09-03-2012, 07:33 PM   #5
Bombastic Idiot
notmrjohn's Avatar
" Pulling that ball of hair out is strangely satisfying." I bet you like to poke road kill with a pointedy stick too. And anyway its not as strangely satisfying as pulling a six foot long 4" cylinder of tightly packed and matted roots out of a toilet drain. With a 5/16" electric drill auger.
pelican you might can snag that hair with that "as seen on TV" snagger, plastic strip with teeth on it. Handy lil gizmo at times. But I'm with ratherbefishing (andI'm notsosurethistime), despite his rather strange obssessions, get a small snake. With the money I've spent renting one over the years I coulda bought a really good 3/8 or 1/2 electric auger.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-04-2012, 03:44 PM   #6
Rewards Points: 155
coat hanger with a hook
Unwind a coat hanger (metal) and make a small hook shape and put that down the drain and twist so as to catch the clog if it's within reach. If this doesn't work THEN buy/rent a real auger as it might be farther down the pipe.
RocketGal is offline   Reply With Quote
The Following 2 Users Say Thank You to RocketGal For This Useful Post:
notmrjohn (09-04-2012), oh'mike (09-04-2012)
Old 09-04-2012, 09:09 PM   #7
Rewards Points: 582
small auger will do the trick.....snake it out...
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 10:06 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
