Slow Running Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-20-2011, 08:08 AM   #1
slow running water
the cold water to the bathtub and washing machine is running at a slow trickle. How do I unstop the water lines?
scrawnykitty is offline   Reply With Quote
Old 07-20-2011, 08:18 AM   #2
Rewards Points: 484
not much info did it ever work?? If so in the cold water hose their is a screen see if it is plug?? as far as the bath tub cold water don't know what kind of tube unit you have. can't help their. Is the cold water ok in the rest of the cold outlet's??
del schisler is offline   Reply With Quote
Old 07-20-2011, 09:02 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Washing machine is most likely clogged screens. Shut off the valves, remove the hoses from the washer and clean the inlets.
The valve probably has whatever is clogging your washer lodged inside of the cartridge or stem. Depending on what brand it is, disassembly can be difficult.
Journeyman Plumber
Old 07-20-2011, 03:45 PM   #4
Tizzer's Avatar
Rewards Points: 470
The supply valves turned on? Has any work been done where the valves were closed?
Both lines simply started to trickle over night or what?
Tizzer is offline   Reply With Quote
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
I hear water running through the pipes, but... DIYtestdummy Plumbing 17 10-29-2008 10:01 PM
