Slow Leak From Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2008, 07:57 PM   #1
Slow leak from shut off valve
I have noticed a slow leak coming from the shut off valve. It looks like there is a coming from the shut off valce right where is the screw is. I have attached a picture of what screw I'm talking about. Will this type of fix require a plumber or is this something a novice should be able to handle?
Slow leak from shut off valve-picture-007.jpg   Slow leak from shut off valve-picture-126.jpg   Slow leak from shut off valve-picture-127.jpg
Topdog is offline   Reply With Quote
Old 06-01-2008, 09:39 PM   #2
Rewards Points: 1,088
Shut off supply to the house, drain the system by turning on the faucets, and then remove and replace the valve.
handy man88 is offline   Reply With Quote
Old 06-01-2008, 09:43 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
You might just need to tighten up the packing nut on the backside of the handle. Try it should stop the leak.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-02-2008, 08:36 AM   #4
Rewards Points: 156
buy a new one
Go to the hardware store and buy a new one... less than $10. The copper ones are the most expensive around $10. It's probably a 1/2 copper pipe coming out with a threaded end. If it's not threaded, you'll have to solder one on. Cut off the main water supply to the house, turn on a faucet at the lowest point in the house (often an outside spigot) so the line will drain and you won't get wet taking the thing off. Unscrew the flexible line that goes to the toilet with a wrench. Then unscrew the valve. All you have to do now is put the new one on and remember to use plumbers tape on the screw threads. It's probably one of the easier projects in plumbing. I'd say novice level if you're worried.
Post a pic of the valve from the top side so I can see if it screws off or if it's soldered on.
jayp is offline   Reply With Quote
Old 06-02-2008, 08:41 AM   #5
Registered User
Termite's Avatar
Agreed, I'd just replace it. Even if the current one is soldered on, you don't have to do that. You can buy a 1/2" compression valve in that same style/configuration. You just tighten it down and you're good to go!
Old 06-02-2008, 08:47 AM   #6
Journeyman Plumber
If you don't want to try my fix fist and your insisting on replacing it then get the same type of shutoff, made by brass craft, the guts are the same across the board, just replace the guts inside it, leave the body in place. No soldering needed, no compressing it on needed, no taking it off of the threaded pipe in connects to.
Old 06-02-2008, 06:15 PM   #7
Hope these extra pics show what you are looking for
Old 06-03-2008, 06:20 PM   #8
my two cents, I'd snug up the supply line and snug up the packing nut on the shut-off first, then if it still leaks go ahead and change out the valve.
DUDE! is offline   Reply With Quote
Old 06-03-2008, 10:57 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
This guy knows whats up!
Journeyman Plumber
Old 06-04-2008, 06:37 AM   #10
Rewards Points: 156
yes
Just shut off the water and unscrew that sucker. Make sure you put plumbers tape on the pipe thread before you put the new one on.
Old 06-04-2008, 07:12 PM   #11
Hey thanks for everyones input, all it needed was a lil tightening. all is good now.
Old 06-04-2008, 07:16 PM   #12
Journeyman Plumber
Old 06-05-2008, 12:02 AM   #13
Doing it myself
Alan's Avatar
That right there is why he makes the big bucks... mmmmmhmmmm.
Journeyman Plumber
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 12:44 PM
Sloan flushometer valve won't shut off BradG Plumbing 3 01-24-2008 09:04 AM
Water Valve won't shut off armywife Plumbing 1 12-17-2007 05:16 AM
Bleeder Valve Leak jwfran Plumbing 1 05-08-2006 08:12 PM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 07:07 PM
