Slow Leak From Pex Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2017, 06:37 PM   #1
Rewards Points: 28
Slow leak from pex connection
I put baseboard hot water heaters in my basement, I finished it a couple months ago. I noticed last night I have a slow drip out of one of the fittings at an elbow/sharkbite cinch clamp fitting. I think my issue was that I put the clamp too close to the elbow, there is pex material showing all around the clamp but i have maybe 1/8" there (it was a tight fit). Is there some way to stop this leak, with some caulking or putty or something, without having to de-pressurize and drain my whole system in the middle of January just to fix this one fitting? Is it possible to put another clamp behind that one? I tried this but couldn't get the clamp together enough to get it to bite.
Any suggestions would be appreciated!
mattsffrd is offline   Reply With Quote
Old 01-10-2017, 07:01 PM   #2
RRH
Rewards Points: 120
Re: Slow leak from pex connection
You can try a regular hose clamp behind that one.
But this will just buy you some time.
Drain the system and fix it right within a few months.
Forget about any caulk or putty idea
RRH is offline   Reply With Quote
Old 01-10-2017, 07:06 PM   #3
Rewards Points: 28
Yeah I plan on draining the system in the spring and doing it right, I just don't want to do it in the winter. I'll try a regular hose clamp.
Old 01-12-2017, 12:19 AM   #4
Rewards Points: 14
Re-crimp it. Use go/no-go gauge.
SHR Plumber is offline   Reply With Quote
Very slow gas leak is okay KCnorthernCA Plumbing 37 10-02-2016 12:46 PM
FIP joint with VERY VERY slow leak daleherman Plumbing 2 03-09-2016 10:25 PM
Sprinkler System leak in connection KrisK Landscaping & Lawn Care 37 09-25-2015 11:11 PM
Slow leak from old shower taps when water on roboth Plumbing 5 08-13-2015 08:59 PM
slow leak homeplumber8 Plumbing 2 08-24-2013 08:58 PM
