Slow Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2013, 04:42 PM   #1
slow leak
Hi everyone,
I trenched my basement and passed inspection with a water test. I ended up letting the water sit and noticed that there is a slow leak. I'm assuming that any drop in water level isn't ok.
What's stopping me from finding the problem is that I have a very high water table where I live in Milwaukee. It's all clay under the house. So I can't see a drip anywhere... it's all already a little moist and was when I first started trenching. In fact, I did end up draining some water (5 gallons) into my trench and it drained through the clay before I had a chance to get to the garage to get my wetvac.
So, should I worry about a drip that probably is just going to get absorbed into the ground?
If so, any thoughts on how to find it? I did try putting plastic under the pvc to see if I can separate drips from the ground water.
Thanks.
homeplumber8 is offline   Reply With Quote
Old 08-24-2013, 05:39 PM   #2
Rewards Points: 582
Originally Posted by homeplumber8 View Post
Hi everyone,
Thanks.
1 st ...its inspected which means inspector was happy with test....2nd you could be leaking through test ball....drain test water and back fill it will be ok .. ben sr
Old 08-24-2013, 08:58 PM   #3
Rewards Points: 1,706
Would it be possible for you to do an air test. Use soap water and look for bubbles. 5 LB is an air test.
The Following User Says Thank You to Ghostmaker For This Useful Post:
joecaption (08-24-2013)
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 08:26 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 06:45 PM
Freon Leak captainron19 HVAC 3 04-16-2010 05:30 PM
Slow leak under sink after fixing clog gunzour Plumbing 4 11-30-2009 10:27 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
