Old 01-08-2009, 02:46 AM   #1
slow flow in bathtub
I just bought a house and the flow seems kind of slow in my master bath tub. House is about 12 yrs old. I'm not sure what kind of faucet it is; but basically turning the round knob controls the flow, and there is another knob on top of that one which will control the temperature. There does not appear to be any leaks or anything.
farmerde is offline   Reply With Quote
Old 01-08-2009, 07:17 AM   #2
Sounds like a Delta. Does the temp control work correctly??? Make sure all shutoff valves are full open, cycle them off/on to be sure. If that does not help, the cartridge could have a partial clog or mineral buildup.
Old 01-08-2009, 09:59 AM   #3
bradnailer's Avatar
Since they are at a tub, there may not be shut off valves. You might try to shut off the water to the house and disassemble the faucet and see if it is grunged up or if there is a seal that is blocking the water flow.
bradnailer is offline   Reply With Quote
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Flow not Pressure problem??? DonM Plumbing 5 11-29-2007 06:53 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
