Slow Filing Toilet, Fill Valve Already Replaced - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2010, 11:12 PM   #1
Slow filing toilet, fill valve already replaced
For some reason the supply line to my toilet has slowed to almost a drip. I've replaced the fill valve and the toilet still did not fill as fast as it should. So I pulled the supply line actually off the wall and turned the valve on. It should have came out and flooded my bathroom but it is barely came out at all. Its very slow. I do not have low pressure anywhere else but at the supply line at this one toilet. Help!
SupraTT is offline   Reply With Quote
Old 12-19-2010, 11:16 PM   #2
Experienced
Jackofall1's Avatar
You may have to replace the shut-off valve seat, or the valve, sometimes the seat comes off them and sits in the valve body blocking the flow. You will have to shut the water off at the main to check this.
Old 12-20-2010, 05:25 AM   #3
Rewards Points: 352
when you shut the water off to the toilet the washer came off the stem, a common problem with stops. If you can find the identical valve you can swap stems(remember to remove the washer that is floating around in the valve). If you can't swap stems you will have to change the stop.
plumberinlaw is offline   Reply With Quote
Old 12-20-2010, 08:06 AM   #4
Household Handyman
Rewards Points: 1,408
Don't laugh--I've seen this one: Is your toilet located at an exterior wall? Could the water line to the toilet be in the exterior wall? With this crazy very cold spell that has hit some areas of the U.S. you "could have" a water line within an exterior wall that has frozen and you are not getting the proper flow even without the stop (valve) on the pipe. This could also happen if the water supply line is below the floor but near the exterior wall of the crawl space and not insulated.
Old 12-24-2010, 06:52 PM   #5
It was the shutoff valve. Replaced it and now the toilet fills like it should! Thanks for all the replies.
Fluidmaster - Slow filling toilet ronniecr Plumbing 12 06-18-2014 06:49 PM
Kohler toilet flush valve yarp1 Plumbing 2 04-01-2010 08:59 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 03:58 PM
