Slow(er) Dry Glue - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2013, 10:00 AM   #1
Rewards Points: 140
slow(er) dry glue
i was at HD looking for slower drying pvc glue. i asked the guy, he said to use cold weather glue. is that the stuff ?
Fix'n it is offline   Reply With Quote
Old 03-02-2013, 10:04 AM   #2
Rewards Points: 12,808
http://www.pvcfittingsdirect.com/_e/...PVC_Cement.htm
Old 03-02-2013, 06:05 PM   #3
Rewards Points: 1,684
Don't forget the PVC primer. Without it the joints will not bond properly. In a few years they will leak.
Old 03-02-2013, 08:50 PM   #4
Roofmaster
Rewards Points: 2,172
I always use cleaner/primer, but do you mean that Flowguard Gold (yellow can) one step will not stay bonded? Just wondered.
Tip: I always use purple primer on 1.5 inches and up, and leave a ring just a little deeper than the socket depth. This tells me when I achieve full engagement.
Old 03-02-2013, 11:30 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 348
The slowest glue I've used is the heavy bodied grey glue. I use it on 6" and larger DWV and pressure pipe
Wood Floors - old glue, something a little different scootermcrad Flooring 13 11-11-2012 07:36 AM
To Glue or Not To Glue denvermatt Carpentry 9 08-22-2011 10:21 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 09:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 12:56 PM
