Slow Drip In Shower - An Easy Fix? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2011, 11:41 AM   #1
Rewards Points: 27
Slow drip in shower - an easy fix?
I have an old shower that I'm going to be re-grouting, but before I do that I need to fix a slow drip from the shower head. The drip slows when I turn the cold handle slightly on, so I'm hoping this is an issue that can potentially be resolved with some adjustment to the handle. I have easy access to the back of the shower knobs through an access panel in a closet behind the shower (seen below).
I'm a plumbing novice, so any help is appreciated with this. Thanks!
mikemcd is offline   Reply With Quote
Old 10-15-2011, 12:26 PM   #2
Mark Potter's Avatar
Rewards Points: 150
Looks like you will need to replace the hole riser to shower it looks like its been leaking on the bottom feeds to shower body as well.
Mark Potter is offline   Reply With Quote
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Installing more than One shower Head tinker67501 Plumbing 4 09-01-2010 10:53 AM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 01:47 PM
