Slow Drip Second Pressure Balance Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2013, 12:03 PM   #1
Slow Drip second pressure balance cartridge
Hi all,
I recently installed a new American Standard Shower valve with Pressure balance unit and cartridge. The unit looks great but it will not completely shut off. There is a continual leak through the shower head.
After three days of trying different things, i had a new pressure balance cartridge sent to me. It was pretty good customer service. Unfortunately when i mounted this one, the same problem has arisen. It will not shut off completely.
Any ideas on what the problem could be? I can't imagine getting two bad pressure balance cartridges.
Cheers
C
tlamurf is offline   Reply With Quote
Old 03-15-2013, 12:36 PM   #2
Rewards Points: 282
Well at least they sent you a replacement for free. Could be a number of things, there are a lot of small parts inside those valves. Check out this utube video disecting the valve while your waiting for the experts to arrive.
link here
jmon is offline   Reply With Quote
Old 03-15-2013, 08:56 PM   #3
There could be debris sitting on the washer not allowing washer to seat properly
joes plumbing is offline   Reply With Quote
Some water pressure issues. Pressure switch and/or sediment filter. mgh-pa Plumbing 2 12-13-2012 09:28 PM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Boiler pressure troubles jduffett HVAC 2 12-12-2010 07:15 AM
Pressure Balance Shower Valve Hammer glenn60 Plumbing 7 06-17-2009 08:30 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 04:50 PM
