Old 10-06-2011, 04:20 AM   #1
Slow drip copper pipe
This spot is a very, very, very slow drip... Discovered it after cleaning out my mothers basement a week ago, so I'm not sure how long it's been dripping before that.
Should I have that section replaced?
Tiny207 is offline   Reply With Quote
Old 10-06-2011, 06:41 AM   #2
Are you absolutely sure it is a drip and not the result of a drop of flux from when the pipe was installed. Flux, if not removed, will oxidize copper and give a variety of colored salts, including the green you see. Some cleaners (e.g., anything with muriatic acid in it) can also cause similar deposits. If you clean it off, does it recur.
If it is a drip, I would repair it. Removing that section will also allow you to see what is going on inside the pipe that may have led to this problem.
John
john4153 is offline   Reply With Quote
Old 10-06-2011, 07:19 AM   #3
Replace section of pipe ASAP.
COLDIRON is offline   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
oh'mike (10-06-2011), plumber666 (10-06-2011)
Old 10-07-2011, 07:39 PM   #4
Mark Potter's Avatar
Looks like hard water issue would cause that hard water will seek any weekness in the copper and start eating it.
H|P Capital
Mark Potter is offline   Reply With Quote
Old 10-09-2011, 07:43 PM   #5
Thank You all! I'm going to get this fixed right away.
Right where my finger is, the darker coloring on the pipe is the water droplet. After I wipe it away it takes over an hour or so to accumulate.
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-14-2011 12:48 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
copper pipe vs pex I'm in trouble Plumbing 4 06-28-2010 12:42 AM
nicked copper pipe analogmusicman Plumbing 3 07-28-2008 09:54 PM
