Slow Drains In Restrooms - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-22-2011, 04:35 PM   #1
Slow drains in restrooms
I am a maintenance tech for a business and I am having an issue I hope you can help with.
We have a men's and women's restroom that are back to back, (sharing the same drain) with 3 sinks in each. One of the sinks in each of the rooms, the most popular, drains very slowly. I have used drano max, liquid plummer gel and some generic acid brand and still the drain does not improve. There is nothing physically blocking the drain such as hair. I have called out a plummer in the past and was told it is the type of soap our janitorial supply uses that causes this. He said there was nothing he could really do and that I should get in the habit of pouring hot water down the drains regularly to help break up the soap. I have tried this as well as everything listed above with little or no improvement. Any other suggestions?
Gorillawizard is offline   Reply With Quote
Old 11-22-2011, 05:09 PM   #2
Rewards Points: 582
call another plumber....have him snake out drain ....get on preventive maintence program using what will work to stop your issues....ben
Old 11-22-2011, 05:13 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 566
Stay away from the drain cleaners and call another plumber
Tags
clogged sink , sink drain , slow drain
New tub drains slow! Geebus General DIY Discussions 12 08-13-2011 08:27 AM
all toilet drains are suddenly slow raevsky Plumbing 16 01-08-2011 09:09 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Slow drains, clogging toilets Keyo77 Plumbing 10 08-16-2007 11:07 AM
tub drains slow new construction clibertyusa Plumbing 5 04-04-2007 12:51 PM
