Slow Draining Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2012, 08:42 AM   #1
Rewards Points: 212
Slow draining sink?
I've got a dual sink in our master bathroom and the left one does not drain as quick/fast as the other side. I've put "Liquid Lightning" in and let is set for the amount of time needed but without any noticeable results.
If I run the water at full blast it will eventually fill up about half way as the water is running.
What do you think I should try?
imola ghost is offline   Reply With Quote
Old 04-09-2012, 08:58 AM   #2
DIY staff
Rewards Points: 7,174
Likely hair and crud stuck to the pop up lever----don't use Drano ever again--now your P-trap and piping is dangerous to work on!!
Reach under the sink--find the pop up lever--there will be a nut holding the lever to the pipe--loosen the nut and pull out the lever---remove the pop up stopper----use a length of wire to fish out the hair--
Replace the stopper--install the pop up rod so that the stopper goes up and down--re install the nut.
If it's still slow--remove the P-trap and clean or replace.
A pair of Channel Lock pliers might be needed,but usually all the parts can be taken apart with your hands.
Be careful--you have Drano in those pipes.---Mike--
Old 04-09-2012, 09:00 AM   #3
Rewards Points: 212
Thanks I'll try that...however I doubt it can be hair since I don't have ANY (completely bald).
Old 04-09-2012, 09:37 AM   #4
DIY staff
Mice hair---happens at night they like to wash up while you sleep!
Old 04-09-2012, 10:01 AM   #5
Rewards Points: 212
I knew someone was using my shaver. Either that or the wife has a friend I don't know about.
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 08:29 PM
Slow draining sink needtoknow Plumbing 3 01-22-2012 01:44 PM
Slow draining sink DDD3 Plumbing 3 08-20-2011 07:13 PM
slow draining bathroom sink brandonriffel Plumbing 6 06-17-2010 01:20 PM
slow draining kitchen sink Slowdrainer Plumbing 2 02-02-2010 12:56 PM
