-   -   Slow draining sink? (http://www.diychatroom.com/f7/slow-draining-sink-139754/)
imola ghost 04-09-2012 09:42 AM
Slow draining sink?
I've got a dual sink in our master bathroom and the left one does not drain as quick/fast as the other side. I've put "Liquid Lightning" in and let is set for the amount of time needed but without any noticeable results.
If I run the water at full blast it will eventually fill up about half way as the water is running.
What do you think I should try?
oh'mike 04-09-2012 09:58 AM
Likely hair and crud stuck to the pop up lever----don't use Drano ever again--now your P-trap and piping is dangerous to work on!!
Reach under the sink--find the pop up lever--there will be a nut holding the lever to the pipe--loosen the nut and pull out the lever---remove the pop up stopper----use a length of wire to fish out the hair--
Replace the stopper--install the pop up rod so that the stopper goes up and down--re install the nut.
If it's still slow--remove the P-trap and clean or replace.
A pair of Channel Lock pliers might be needed,but usually all the parts can be taken apart with your hands.
Be careful--you have Drano in those pipes.---Mike--
imola ghost 04-09-2012 10:00 AM
Thanks I'll try that...however I doubt it can be hair since I don't have ANY (completely bald).
oh'mike 04-09-2012 10:37 AM
Mice hair---happens at night they like to wash up while you sleep!
imola ghost 04-09-2012 11:01 AM
I knew someone was using my shaver. Either that or the wife has a friend I don't know about.
