Old 02-19-2011, 11:43 PM   #1
Slow draining bathtub
I just moved into a 100 yr old house. By the time I finish taking a shower I'm standing in 6 inches of water and the toilet is gurgling. I tried snaking it through the overflow but the snake will only go in about 6 inches and won't go in any further. Please help me Get this drain opened.
IntensitySoftba is offline   Reply With Quote
Old 02-20-2011, 11:39 AM   #2
If your toilet is gurgling (burping?) the problem is downstream and a larger cable (1/2-5/8) sent thru the closet bend after removing the toilet would be more effective. Before I would do that I would remove all the cleanout caps, run water to determine where the problem is exactly. Frequently it is the main line going to the city sewer or septic(septic is a another story)
plumberinlaw is offline   Reply With Quote
Old 02-20-2011, 12:12 PM   #3
Hvac Pro
OR the main vent/stack where it penetrates the roof of your house is frozen or plugged partly with a birds/squirrels nest etc.
Old 02-20-2011, 02:36 PM   #4
Thanks guys... I was thinking it might be the vent stack as well. Gotta get a bigger snake to run through that line. I keep y'all posted.
Sent from my iPhone using DIY Forum
slow bathtub drain with yucky scum in tub redphoenix Plumbing 7 02-19-2011 11:29 AM
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 6 09-22-2010 06:43 PM
slow draining bathroom sink brandonriffel Plumbing 6 06-17-2010 02:20 PM
bathtub draining slowly needtoknow Plumbing 2 06-01-2010 02:11 AM
