Slow Drain Fast Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2012, 04:14 PM   #1
Rewards Points: 150
Slow drain fast drain
My bathroom sink, a vessel sink, drains really slowly at first and then after about 2-3 inches of water builds up suddenly starts draining really fast, almost making a sucking noise. Then it looks like the water only drains down as far as the bottom of the sink instead of further down.
Whats going on?
I can post a video of it later if an example is needed.
knotquiteawake is offline   Reply With Quote
Old 06-15-2012, 11:28 PM   #2
A vid would be helpful.
VIPlumber is offline   Reply With Quote
Old 06-16-2012, 08:57 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by knotquiteawake View Post
My bathroom sink, a vessel sink, drains really slowly at first...
Is this a new issue or has it always been like this?
Whats going on?
Old 06-16-2012, 12:28 PM   #4
Rewards Points: 150
its been like this since we moved in a couple months ago. The sink is new; part of a remodel done before we moved in.
Here is a video of it in action.
The sink starts to back up, draining very slowly, and then at some critical mass or something suddenly rapidly drains and then starts to backup again. Rinse and repeat...
http://youtu.be/nue-_TiO0Qo
Old 06-16-2012, 01:41 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 352
Do me a favor would ya? stick a drinking straw in the strainer an inch or so. Does it drain better?
Old 06-16-2012, 02:10 PM   #6
Rewards Points: 150
not at one inch but after wiggling the straw about 2.5 inches down it drained like I would expect a normal sink to.
Old 06-16-2012, 02:47 PM   #7
Plumber
Rewards Points: 352
This problem is not uncommon with grid strainers. One remedy is to replace the strainer with a larger hole pattern or a popup model. Others have had success drilling the existing holes larger
Old 06-16-2012, 06:08 PM   #8
I agree with Eplumber, replace the strainer. Looks like this one takes longer than expected to allow the water break through the holes.
Need a cheap fix to slow bathtub drain need help Plumbing 11 04-26-2016 10:11 AM
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Slow drain is still slow dav7612r Plumbing 14 08-01-2010 10:28 AM
Slow kitchen drain - tried almost everything! Critical Mass Plumbing 17 07-15-2009 08:57 AM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
