-   -   Sloan flushometer valve won't shut off (http://www.diychatroom.com/f7/sloan-flushometer-valve-wont-shut-off-16055/)
BradG 01-23-2008 11:27 PM
I had my toilet disconnected for maybe 2 or 3 weeks during renovation and now that I've hooked it back up, the valve won't shut off once flushed. I've tried playing with the flow-screw to no avail.
The valve is sealing properly. When I turn the water on at the flow-screw, it holds until flushed but then it just keeps flowing without shutting off again.
Is there some secret to re-setting these valves or something? I haven't tried pulling the mechanism apart yet. I was sort of hoping that it might reset itself but it's been several days now. I've been manually flushing by turning the flow-screw on, flushing and then turning the screw all the way off.
jpplumber 01-24-2008 02:33 AM
More than likely you need to replace the diaphragm. Make sure you get the same GPM...they come in 1.6 GPM on newer toilets and urinals but need more volume on older units.
Marlin 01-24-2008 05:28 AM
Their is a trick to re-setting them. I don't know what it is though. If you try and flush a flushometer while the water is off you have to do something or else you get the exact problem you are having, the water won't shut off.
I imagine even if you don't try and flush them after several weeks you may have a problem.
majakdragon 01-24-2008 09:04 AM
Turn off the water supply. Unscrew the top of the valve. You should see a piece of plastic. Pick it up and you will see the diaphram. On it, you will see a shiny piece of metal. It has a small hole in it. Try blowing through the hole to clear it. This hole allows water to go through and equalize the pressure which is what shuts the valve off after a flush. I have also used a needle to clear debris from it.
