Old 03-04-2008, 09:44 PM   #1
RDS
Slip nuts
Should the slip nuts on the P-trap under my bathroom turn in the same direction, or in opposite directions? I got the front one off easily, turning counterclockwise (looking down on it), but the back one won't budge either way. Just wondering which way I should be turning to get it off.
(Thought I'd better ask this time since, with a prior plumbing inquiry, I learned I was turning a nut the wrong way!)
Thanks.
RDS is offline   Reply With Quote
Old 03-04-2008, 09:45 PM   #2
RDS
Slip nuts
Sorry -- I meant to say "bathroom sink". In case in matters.
Old 03-05-2008, 10:30 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Slip nuts
Righty tighty, lefty loosey.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-05-2008, 11:05 AM   #4
RDS
Slip nuts
Thanks. I've heard of that rule, but by wrecking a table saw arbor once doing 'lefty loosey', I learned that there are occasionally exceptions. I was just wondering if this was one of those cases.
I guess what I'm wondering is: Left when looking down on the nut, or left when looking up at it from underneath? Sorry, I realize this is probably Plumbing 101 but I'm a complete novice. Thanks.
Old 03-05-2008, 11:10 AM   #5
Journeyman Plumber
Slip nuts
Unless your looking at the nut from the backside of it then it's opposite. Looking down on the nut left is loose. From bottom it will be right.
Laws of physics got to love em.
Old 03-05-2008, 11:26 AM   #6
Slip nuts
Normally, the only "left-handed" nut in a bathroom is on the toilet flush handle, the one that holds it in place. Everything else should be standard.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-05-2008, 12:59 PM   #7
RDS
Slip nuts
ok thanks guys. guess i need to eat my spinach, and/or get a pipe wrench, 'cause my channel lock pliers are not giving me a good grip on the nut. cheers.
insulation question, Or am I nuts Oldhouseowner General Discussion 15 12-27-2008 02:51 AM
Frozen brass slip nut michael76 Plumbing 4 12-22-2007 11:23 PM
3 way circuit drving me nuts! hubbard53 Electrical 5 11-17-2007 02:50 PM
Nuts And Bolts And Thingamajigs slickshift Off Topic 0 05-02-2007 09:24 AM
Window doesn't slip well Not Sure Building & Construction 3 08-12-2006 09:12 AM
