Slight Sewer Smell In Kitchen - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2010, 08:32 PM   #1
Slight sewer smell in kitchen
This morning I woke up to find that when I got up and got a drink of water last night I didn't completely turn off the faucet so it was running very slowly almost all night. I also noticed that along with this came a very faint sewer smell. So faint that my wife can't even smell it. The trap appears to be holding water and I checked the basement and there seems to be no leaks in the drain pipe. No other fixtures smell, nothing in the bathroom or laundry room which are the only other rooms with plumbing. What could be causing this? Is it due to having the water run all night? Any help would be appreciated. Thanks in advance!
nosbusch2005 is offline   Reply With Quote
Old 07-28-2010, 08:45 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
It could be as simple as scum build up in the tailpiece or disposal. The water running maybe just a coincidence. Do you have an auto vent at the trap? It may be stuck open. Do you see any moisture where the pipe exits the floor/ceiling in the basement? Possible cracked pipe. just some thoughts. These can be very hard to pinpoint
Old 07-28-2010, 10:18 PM   #3
Owner
LateralConcepts's Avatar
Many times odors are mistaken for sewer smells. As TheEplumber mentioned it's most likely just grime built up in the trap, disposal, trap arm, or a dishwasher tailpiece? If you have a disposal run a cup of ice through it with some type of citrus cleaner or lemon juice.
You may also want to try drawing a glass of water and smell it. If it smells like sulphur (rotten eggs or a geyser). It's most likely a bad magnesium anode rod in your water heater. Which would need to be replaced with stainless steel, aluminum, or zinc.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-29-2010, 07:14 AM   #4
Thanks for those tips guys I will give those things a try.
sewer gas smell when using washer cgratsch Plumbing 6 01-27-2014 12:09 AM
Studor Mystery: Sewer Gas Smell StudorCrazy Plumbing 3 02-20-2010 11:49 AM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
