-   -   Sleeve options for plumbing through concrete? (http://www.diychatroom.com/f7/sleeve-options-plumbing-through-concrete-3028/)
Bruce L 07-10-2006 09:54 PM
Fantastic forum/resource! Thanks much to the creators, and especially everyone willing to share so much of your time and knowledge!
I will be running pvc water supply and waste lines through through a concrete foundation wall and am wondering what options there are to sleeve the pipes within the concrete. The structure is a garage w/ a second story studio. The foundation wall is 8" thick concrete, rising approximately 1' above grade, with a slab poured seperately. My intention is for both the water and waste lines to enter the foundation wall approximately 1' below grade, (this is in Austin, TX - no frost line), and immediately turn 90 degrees upward within the concrete wall, to exit the concrete foundation stemwall directly within the the first floor wall framing.
Question 1. Is it okay to have pipe transitions buried within the concrete, (the 90 degree upward bends in this case, (..actually 2 contiguous 45 degree bends for the 3" waste line))?
(This allows me to keep all plumbing within the walls).
Question 2. What options are there to sleeve the pvc pipes in the concrete?
(I see reference to providing "sleeves" for all pipes through concrete in the 2003 UPC code, (the pertinent code here), but I do not know what is acceptable as a "sleeve". Given the "L", or 90 degree bend that will be entirely within the concrete, using a larger diameter pipe as the sleeve is not possible. I see job sites where it appears that pvc or copper running through concrete, (with bends/joints cast within as far as I can tell), are merely wrapped in plastic, (sometimes blue, sometimes black).
If anyone can offer advice, much appreciated.
Bruce
Ron The Plumber 07-10-2006 10:51 PM
First off, here you can not have fittings for water under a slab, and pipe must be protected that passes through the slab, i.e. wrapped foam insulation, here PVC water lines is not permitted within the foundation of a structure. Waste lines are allowed under the slab, and these to need protection, but no sleeve is required. Here we would use soft cooper or pex water pipe with no fitting under the slab. UPC code here we use, and it states no pipe will be directly embeded in cement. It will be protected.
Bruce L 07-11-2006 02:30 PM
Thanks Ron. That definitely helps. I didn't know if foam insulation was adequate by UPC, and PEX or Soft copper certainly makes sense.
Bruce
Ron The Plumber 07-11-2006 06:52 PM
Yea Bruce, just wrap the foam around the parts that will pass through the slab, and tape it up, thats how we do it here.
Bruce L 07-12-2006 03:36 PM
Excellent. Thanks Ron.
jpiers 06-14-2008 10:09 AM
Hi ron,
What career are you in to? You seemed to be an expert with this type of job ;)
Ron The Plumber 06-14-2008 10:38 AM
Originally Posted by jpiers (Post 130337)
Hi ron,
The same as you
