Old 12-04-2011, 08:00 PM   #1
crankcase's Avatar
slamming check valve on basement ejection pump
I have a check valve mounted about 18" above floor level for my ejection pump. Any time we do laundry or the water softner cycles we hear the slamming of the check valve every 5-8 minutes after the pump stops.
How can I quiet or eliminate the loud slam of the check valve? Maybe another check valve closer to the ceiling?
crankcase is offline   Reply With Quote
Old 12-04-2011, 08:25 PM   #2
Is it all metal pipe? Through which the sound would resonate?
If yes, how about isolating the check valve from the metal pipe with rubber or plastic connections?
Billy_Bob is offline   Reply With Quote
Old 12-04-2011, 08:27 PM   #3
crankcase's Avatar
No metal it's 2" ABS.
Old 12-04-2011, 09:15 PM   #4
And a 2" check valve? Good grief!
Do you need that large?
It is of course the weight of all that water falling back down on the check valve. And that would be reduced with the valve higher up as you suggested. (Less water weight.)
And/or a smaller line and be no smaller than the pump output of course. But with a smaller line, then less water weight...
Old 12-04-2011, 09:38 PM   #5
crankcase's Avatar
Pretty sure the pump has 2" outlet. We just had the house built this is our second winter. I was thinking an additional check halfway up the run. Just wasn't sure if there were any other solutions.
Check valve for column sump pump fjacky Plumbing 5 03-13-2012 09:33 PM
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Help with check valve on recirculating pump joeq Plumbing 21 10-08-2011 05:24 PM
Lift station check valve noise atDev Plumbing 2 08-18-2011 09:24 AM
Do I need seperate vent stacks for basement pump and basement sink? twinfins Plumbing 5 12-08-2010 12:28 AM
