Slab Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-28-2012, 05:49 PM   #1
Slab Plumbing
Hello all, I'm doing a shower renovation and i have a question about exiting piping. How do i remove the concrete away from the 2"abs piping located in the slab so i can connect a 2" Kerdi drain to the existing abs pipe? Any help would be appreciated.
We on is offline   Reply With Quote
Old 05-28-2012, 06:05 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by We on View Post
How do i remove the concrete away from the 2"abs piping...
Carefully.
Old 05-29-2012, 01:15 AM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
proceed with caution
wctekkk is offline   Reply With Quote
Old 05-29-2012, 06:21 AM   #4
Rewards Points: 1,216
There is no easy way to do that you just have to saw cut or jackhammer the floor all around the area and replace the pipe where it broke with your new connector.
COLDIRON is offline   Reply With Quote
Old 05-29-2012, 01:29 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
post some pictures so folks will have a better idea of what you're up against.
HRG
Homerepairguy is offline   Reply With Quote
Old 05-29-2012, 02:22 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
The plumbing is not in the slab, it is under the slab. You might break a riser coming up thru the slab but that is easily repaired.
Coastal South Carolina
Relocating plumbing - concrete slab foundation vsheetz Building & Construction 17 04-23-2011 05:22 AM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 01:49 PM
moisture under slab, roughed-in plumbing bergerdude Building & Construction 4 03-25-2011 08:29 PM
Plumbing through a slab phxhome Plumbing 7 09-01-2010 11:50 AM
