Slab Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-10-2012, 09:33 PM   #1
Slab leak?
I own a townhouse in a triplex and have a water leak coming from the neighbors slab. I thought it was my waterline running from the street up to the turn off valve but after many test and digging it's not coming from my line. My line runs parallel with the neighbors slab. I dug down to her slab and could see water running out of the neighbors slab.
This morning I emptied a freshly dug hole of all water. I turned the neighbors water off at the street and drained her lines from the lowest hose bib, within 2 hours the hole had 8 inches of water. With all three units water turned off at the street the water continues to flow out from the neighbors slab. This continued all day today with the water turned off at the street. What can I do to find the source of the water?
Thanks,
Justin
Charleston, SC
JustinTime2 is offline   Reply With Quote
Old 10-10-2012, 09:37 PM   #2
Rewards Points: 14,010
Could be an underground spring.
Old 10-10-2012, 09:44 PM   #3
Thanks fro your reply. That was all i could come up with but living on the coast and in the same townhouse for 26 years and never having this problem until recently it's doubtful.
Justin
Charleston SC
Want to Install Ceramic/Porcelain and Insulate Basement Slab illusion8055 Building & Construction 2 08-15-2012 01:19 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Pier on slab cer2012 Building & Construction 0 04-16-2012 08:52 PM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
