Old 04-02-2009, 05:06 PM   #1
slab cut
The slab is cut out for the tub drain, about 20" x 18". I reckon that hole needs some kind of seal after the plumbing work is done these days, but apparently in 1953 they left these holes open to the ground. What is the best way to handle sealing this up?
7echo is offline   Reply With Quote
Old 04-02-2009, 10:11 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
slab cut
you dont seal it up. its left open so that if the trap needs to be worked on, you dont have to bust up concrete to get to it. that being said however, 20X18 seems rather a large section. If you still want to seal it up, I'd box out the piping then just use a bag of concrete mix.
JDC is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Can I set a cabin on top of mobile home slab? birchbarx Building & Construction 4 03-22-2008 07:06 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 08:37 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
