Skeh123 - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2011, 07:30 PM   #1
well pump cycles under no load
i bought a home (HUD) and am having trouble with the well. it is a 5" well and according to the county is about 135' deep. the water line comes out through the top, over to the old well house into the switch and tank. I have unhooked the line (water) from the switch, turned it away to free flow onto the yard. I have applied power through a 20 amp breaker 230 volt. the pump runs for about 3 seconds with a good amount of water coming out, then stops for about 45 seconds and repeats this indefinitely. i dont believe the pump is down any where near 135'. It has 1 red 1 black and 1 green wire, no pitless and the well has been used no more than two years and has been sitting unused for about two years. any ideas?
skeh123 is offline   Reply With Quote
Tags
well pump cycles
