| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Make a Solar Pump
by eHow.com
When you need to pump water to a distant field, sometimes it's not convenient to run the pump with electricity. In such an application, a solar pump works well. Fortunately, you can do this yourself. This eHow can help you get started. Read More » Hydraulic systems normally work with fluids that are stored under a great deal of pressure. Having the right amount of pressure for hydraulic systems can increase work efficiency and reduce mechanical failure and injury. Luckily you can determine the... Read More »
How to Dispose of a Septic Tank
by eHow.com
Many people have decided to abandon their old septic systems and tanks and get tied into the public sewer system in their area. This decision leaves homeowners with unused septic tanks on their property. Although septic tanks are buried underground, the... Read More »
How to Remove a Shower Head
by Expert Village
GPM stands for gallons per minute. And that determines how much water comes out your shower when you're taking a shower. You want to think about a low flow shower head. Low flow shower head come in two different kinds. We have one that's aerating and one... Read More »
How to Save Money on Propane
by eHow.com
Propane can be an economical way to heat your home. There are portable propane tanks you can use for grills or to heat campers. There are even vehicles powered by propane. Let's look at some ways to save money on this fuel. Read More »
