Sizing Water Supply Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2011, 09:41 PM   #1
Question
Sizing water supply line
Hello all!
I am new to the site and hoping for some help...
New construction of a 4BR/2Bath ranch house in country. Will be on county water (not sure of flow rate yet) via a 3/4" meter. House will be about 500 feet from the meter (negligible elevation change). What would be the recommended SCH 40 PVC size supply line from the meter to the house? I have been told 1" , 1 1/2", someone even suggested 2", so I appeal to you guys for a definitive answer!
Thanks!
davemh is offline   Reply With Quote
Old 08-17-2011, 10:43 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Need to know your pressure to size it correctly
Old 08-18-2011, 05:44 AM   #3
OK. I will check with the county and update the thread.
Thanks!
Old 08-18-2011, 08:09 AM   #4
Plumb or Die!
While you're talking to the county, see if sched 40 pvc is allowable in your area.
plumber666 is offline   Reply With Quote
Old 08-18-2011, 05:40 PM   #5
The county is telling me 80-100 psi. That sure seems high, but I don't have the meter yet, and I guess they would know!
Old 08-18-2011, 09:36 PM   #6
Plumber
Rewards Points: 348
that is not uncommon pressure in my area.
So, now you know your pressure, length, elevation change and fixture load. All you have to do now is use google or your library to find sizing charts, plug in your info and you're set! Or perhaps your water district might have the info. I'd do it for you but my code book is at the jobsite
Old 08-21-2011, 07:58 AM   #7
After running the numbers on an internet sizing calculator, it looks like I should use a 1 1/4" supply line.
Is there any benefit (or perhaps negative impact) if I were to use an 1 1/2" SCH 40 supply line the entire 500'? Then reduce it back down to 3/4" where we will tie it into the house?
Old 08-21-2011, 09:31 AM   #8
Plumb or Die!
The benefit would be that you have more options with a larger pipe. Like adding outbuildings in the future. Drawbacks? Just cost, nothing else.
The Following User Says Thank You to plumber666 For This Useful Post:
davemh (08-21-2011)
Old 08-21-2011, 09:34 AM   #9
Great! That may be the way to go then; better to do it right the first time and future proof a bit, than try and go back and do it again.
Thanks for all the advice!
Old 08-21-2011, 09:36 AM   #10
Plumb or Die!
Lots of primer, lotsa glue, and have fun!!
Old 08-21-2011, 09:54 AM   #11
Civil Engineer
Rewards Points: 4,514
At 500 feet, you may want to look into continuous pipe. You can generally get HDPE (high density polyethylene) or PEX in continuous rolls, you may even be able to get a 500 foot roll. If your municipality allows it for buired water supply, this will avoid the need to join pieces of PVC.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
davemh (08-21-2011)
Old 08-21-2011, 09:56 AM   #12
Ahh, I hadn't considered that, will definitely look into it, thanks!
Old 08-22-2011, 04:11 AM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
youll have plenty of volume that way,then just reduce it to 3/4 somewhere before meter.
I ran a water service almost 1500' one time,started with 2" k copper finally got it down to 1" just before entering house.
his old service ran about same distance but came in 3 blocks over through a cemetary to another main,it was only a 3/4" service all the way! he was much happier with the new water!
plummen is offline   Reply With Quote
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 08:39 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Removing Water Line Obstruction Mickey53 Plumbing 11 12-15-2009 12:39 PM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 09:51 AM
