Old 01-26-2008, 05:45 PM   #1
Sizing a hot water heater.
My wife and I are building two adjoining guest houses that will have a full bath in each.
With a maximum capacity of four adults at any one time, what capacity water heater should I get to assure that everyone gets a hot shower?
added note: The electric service is not sized for an on demand water heater.
Randell Tarin is offline   Reply With Quote
Old 01-26-2008, 05:53 PM   #2
Eibwen
I would go with a 50 gallon tank. Look for the fastest recovery time you can find within reason. Insulate the pipes and make sure you have a low flow shower head in place.
Ya'll
Sammy is offline   Reply With Quote
Old 01-26-2008, 06:02 PM   #3
50 gallon was about what I was thinking. I have another problem with hot water heaters out here.
We're on well water with a high mineral content. If we are gone for a few days from our home the hot water aquires the smell and taste of rotten eggs.
It takes a volume of water to purge the lines after that.
From what I've read, it's a bacteria reacting with the anodes within the hot water heater tank itself. If I turn the water heater off, the smell is not as strong. I'm thinking about putting an electric shutoff on the new water heater.
Another solution would be to filter the water coming into the house or add chlorine.
Any other suggestions?
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
