Old 12-08-2012, 09:04 PM   #1
size of supply lies for new bathroom
i am building an addition with a full bathroom. i am bringing the hot and cold supply lines to it with 3/4" lines. i plan to transition down to 1/2" lines right at each individual fixture. is this ok or should i step down to 1/2" as i come off the main lines and run the individual supplies in 1/2"?
gwilkrrs is offline   Reply With Quote
Old 12-08-2012, 09:09 PM   #2
1/2" off of the main line.
Old 12-08-2012, 09:54 PM   #3
ok- i was wondering because off the main lines i will run about 16'-20' to each fixture and didnt know if the 3/4" would hold more water for those distances.....
Old 12-09-2012, 12:09 AM   #4
3/4 lines allow over twice the volume of 1/2 inch however, unless your water pressure is very low the 16 -20 foot 1/2 inch lines should handle the flow easily. UNLESS..you ARE INSTALLING SOMETHING LIKE A SUPER SHOWER WITH 6 HEADS!!then 3/4 might be required.
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
gwilkrrs (12-09-2012)
Old 12-09-2012, 07:39 AM   #5
nothing fancy in there- double vanity, ttoilet and standard shower. just dont want to goof this up and wish i had more
Old 12-09-2012, 11:05 AM   #6
I n my last house where I acted as General Contractor I was on a well and had 3/4 mains in basement with 1/2 inch to fixtures including MB ensuite on second floor which was farthest from pressure tank (65') with no problems. When we sold, the home inspector ran the tub, shower and sink full blast then flushed the toilet with no discernible drop in flow and gave it the ol'
Old 12-09-2012, 04:21 PM   #7
Plumber
Just run 3/4" to the bathroom then 1/2" to the fixtures.
The cost difference is minimal for a job this size.
DidIDoThat is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Help with return and supply size XHornet85 HVAC 9 09-17-2008 12:13 AM
Pipe size for supply run napper Plumbing 3 09-07-2008 01:39 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
bathroom sink supply line height bluebee1314 Plumbing 2 03-28-2007 06:47 AM
