Old 02-02-2011, 01:25 AM   #1
Size of hole for 1/2" copper pipe through floor
Pretty simple question. How snug should the hole be that a copper pipe runs through? I bought an 11/16" bit for 1/2" copper pipe.
How much expansion and contraction should one allow for? I noticed there is another place in my house where 1/2" copper is running through, but the previous H.O. used like a 1" bit.... looks sloppy, but got me second guessing myself.
FirstAndTen is offline   Reply With Quote
Old 02-02-2011, 02:18 AM   #2
I normally run 3/4" bits for 1/2 copper. I dunno why just what I have always done lol.
proremodel is offline   Reply With Quote
Old 02-02-2011, 07:53 AM   #3
1/2" copper is 5/8OD, you do not want the hole to fit tightly or you will get squeaking, ticking as pipe expands. As suggested 3/4" or larger.
Old 02-02-2011, 08:41 AM   #4
old guy contractor
tcleve4911's Avatar
I've always used a 1"
It gives room for play and is usually covered by a cover plate anyway
tcleve4911 is offline   Reply With Quote
Old 02-02-2011, 09:42 AM   #5
call me E
TheEplumber's Avatar
1 3/8" with pound-in isolators
The Following User Says Thank You to TheEplumber For This Useful Post:
the_man (02-02-2011)
Old 02-02-2011, 10:27 AM   #6
Can anyone find a photo of a "pound-in isolator" or a "cover plate" as described above?
Thanks for the replies!
Old 02-02-2011, 01:33 PM   #7
Persona Non Grata
VIPlumber's Avatar
The pound in isolator looks like this
and is called a pex suspension pipe clamp (I know it as mickey mouse ears)
and the cover plate is known as an escutcheon plate/ring.
VIPlumber is online now   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
FirstAndTen (02-03-2011)
Old 02-02-2011, 08:46 PM   #8
call me E
My version of pipe isolator
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
FirstAndTen (02-03-2011), tcleve4911 (02-02-2011)
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
12/2 wire in contact with Hot water pipe (copper) - Dangerous? Tryvidy Electrical 6 04-21-2009 08:35 PM
Reducing size of very large air-vent returns in floor? AllGoNoShow HVAC 3 09-19-2006 10:36 PM
