-   -   Size of hole for 1/2" copper pipe through floor (http://www.diychatroom.com/f7/size-hole-1-2-copper-pipe-through-floor-94285/)
FirstAndTen 02-02-2011 12:25 AM
Pretty simple question. How snug should the hole be that a copper pipe runs through? I bought an 11/16" bit for 1/2" copper pipe.
How much expansion and contraction should one allow for? I noticed there is another place in my house where 1/2" copper is running through, but the previous H.O. used like a 1" bit.... looks sloppy, but got me second guessing myself.
proremodel 02-02-2011 01:18 AM
I normally run 3/4" bits for 1/2 copper. I dunno why just what I have always done lol.
Just Bill 02-02-2011 06:53 AM
1/2" copper is 5/8OD, you do not want the hole to fit tightly or you will get squeaking, ticking as pipe expands. As suggested 3/4" or larger.
tcleve4911 02-02-2011 07:41 AM
I've always used a 1"
It gives room for play and is usually covered by a cover plate anyway
TheEplumber 02-02-2011 08:42 AM
199 Attachment(s)
1 3/8" with pound-in isolators
FirstAndTen 02-02-2011 09:27 AM
Can anyone find a photo of a "pound-in isolator" or a "cover plate" as described above?
Thanks for the replies!
VIPlumber 02-02-2011 12:33 PM
The pound in isolator looks like this
http://www.pexuniverse.com/sites/def.../PXA4711_3.jpg
and is called a pex suspension pipe clamp (I know it as mickey mouse ears)
and the cover plate is known as an escutcheon plate/ring.
http://img3.prosperent.com/images/25...6002853-00.jpg
TheEplumber 02-02-2011 07:46 PM
199 Attachment(s)
My version of pipe isolator
yuridingmayl 09-05-2013 07:00 PM
Pipe Isolator?
Redacted
Fix'n it 09-05-2013 09:25 PM
hey guys. would it be ok to fill the gap with caulk ?
TheEplumber 09-05-2013 09:38 PM
199 Attachment(s)
It's good practice to use an isolator.
Energy code in my area requires the hole to be sealed with foam- if it is coming from the crawl space
Fix'n it 09-05-2013 09:43 PM
ok, will do. do those isolators hold the pipe ?
wkearney99 09-05-2013 09:44 PM
Some areas require it to be the red fire blocking foam.
TheEplumber 09-05-2013 09:47 PM
199 Attachment(s)
To a point. The pipe will slide if you push or pull
