Old 09-19-2010, 04:51 PM   #1
size of drain pipe
What size pipe do you need to drain 2 washers?
eice is offline   Reply With Quote
Old 09-19-2010, 05:00 PM   #2
Super Moderator
size of drain pipe
A little more of an explanation--are you installing two washing machines?
If so each one will need its own 2" drain and 1 1/2 inch vent.--2 machines=2 drains.
Old 09-19-2010, 07:25 PM   #3
size of drain pipe
I live in a condo. the unit above me has a washer. the waste line I want to tie into is 2". Is that large enough line to carry water from both units?
Old 09-19-2010, 08:45 PM   #4
Super Moderator
size of drain pipe
You should be o.k---Hard to tell without actually seeing the piping--You will need to have a vent pipe within 5 feet (I believe)--There are several licensed plumbers here--Let's see what they have to say--
If you can post a picture or a sketch of the plumbing--drains and vent--that would be very helpful.--Mike--
Old 09-19-2010, 09:03 PM   #5
call me E
TheEplumber's Avatar
size of drain pipe
A 2" horizontal pipe will handle 8 drainage fixture units. 2" vertical pipe will handle more so you will be ok. But plese read this thread in regards to suds relief- Multi-Units
Like oh'Mike said- 1.5 in. vent is needed
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Replacing shower drain all connectors, no pipe nkovach Plumbing 0 06-21-2010 10:15 AM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 11:32 AM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
