Old 06-06-2009, 12:57 PM   #1
Sink won't drain
Hello everyone. My kitchen sink won't drain properly. If I leave the faucet on for a while it will stop draining. If I do the dishes and let out the water, it will drain for a while then stop. Eventually all the water will drain but it takes a while. I took out the drain pipes and trap and inspected - all looks good with no blockage. While the sink wasn't draining I started to take off the cheater vent under the sink and it started to drain. I replaced the cheater vent last night. Just did the dishes this morning and it still won't drain. Any idea's. Thanks in advance.
kchopper is offline   Reply With Quote
Old 06-06-2009, 01:54 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Sink won't drain
For kitchens it's grease; for bathrooms it's hair.
I usually force hot water down the drain for a few minutes, either directly from the water heater bottom drain through a garden hose, or with an adaptor that mates with faucet threads and provides a hose thread.
You can use rags as a gasket between the hose and the pipe.
Old 06-07-2009, 01:21 AM   #3
Oldie but Newbie
Sink won't drain
The fact that it works for awhile and then stops suggests that the clog is a ways down the pipe.
Do you have a cleanout opening outside the house? If so, you may try "snaking" the pipe through the cleanout.
LookoutRanch is offline   Reply With Quote
Old 06-07-2009, 02:08 AM   #4
Sink won't drain
Agreed, probably grease. Over time, it's amazing how much percentage of a pipe can be filled with grease...
Old 06-07-2009, 10:39 AM   #5
Sink won't drain
Thanks for the replies. I will try and see if I can get into the pipe and snake/clean it out. Thanks again
Old 06-07-2009, 10:42 PM   #6
Sink won't drain
could be grease but take connection of trap off could be something stuck in thereuse a bucket if theres no cleanout not outside problom
doody is offline   Reply With Quote
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 02:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
