-   -   Sink won't drain (http://www.diychatroom.com/f7/sink-wont-drain-46082/)
kchopper 06-06-2009 11:57 AM
Sink won't drain
Hello everyone. My kitchen sink won't drain properly. If I leave the faucet on for a while it will stop draining. If I do the dishes and let out the water, it will drain for a while then stop. Eventually all the water will drain but it takes a while. I took out the drain pipes and trap and inspected - all looks good with no blockage. While the sink wasn't draining I started to take off the cheater vent under the sink and it started to drain. I replaced the cheater vent last night. Just did the dishes this morning and it still won't drain. Any idea's. Thanks in advance.
Yoyizit 06-06-2009 12:54 PM
For kitchens it's grease; for bathrooms it's hair.
I usually force hot water down the drain for a few minutes, either directly from the water heater bottom drain through a garden hose, or with an adaptor that mates with faucet threads and provides a hose thread.
You can use rags as a gasket between the hose and the pipe.
LookoutRanch 06-07-2009 12:21 AM
The fact that it works for awhile and then stops suggests that the clog is a ways down the pipe.
Do you have a cleanout opening outside the house? If so, you may try "snaking" the pipe through the cleanout.
vsheetz 06-07-2009 01:08 AM
Agreed, probably grease. Over time, it's amazing how much percentage of a pipe can be filled with grease...
kchopper 06-07-2009 09:39 AM
Thanks for the replies. I will try and see if I can get into the pipe and snake/clean it out. Thanks again
doody 06-07-2009 09:42 PM
could be grease but take connection of trap off could be something stuck in thereuse a bucket if theres no cleanout not outside problom
