Sink + Washer Piping - Help? Pls? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2010, 12:39 PM   #1
Question
Sink + washer piping - help? pls?
Hi,
I am re-doing my basement. It had a rough-in for a small washroom. I'll use this space to install a utility sink + washer/dryer.
I am a little stumped as to how to connect the drain for the sink as well as the waste water output from the washer. The rough-in pipe for the sink is pretty obvious, but I can't see any other obvious vent. So I figure I need to install a cheater-vent. I have attached a diagram (see below... hopefully) and would very much appreciate feedback to know if this is OK or will I be breaking some mystic plumbing rule.
Tx!
globus999 is offline   Reply With Quote
Old 09-03-2010, 11:17 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Wow....yeah you'll be breaking a big plumbing rule there....as in that just wont work. Everytime the washing machine discharges its going to back up into your utility sink.
Since you're going to be installing a utility sink (I'm reading laundry tub) anyway, you could just discharge the washing machine directly into the tub. If you just have to have a standpipe for your washing machine then you're going to have to cut a tee into the stack, install a 2" trap and standpipe. The one vent can serve as a common vent for both the sink and the standpipe. Not the best set up but it should work. However, this is assuming that the stack is at least 2" or bigger.
If it were me I'd just install a laundry tub and discharge the washing machine into that.
Good luck
JDC is offline   Reply With Quote
The Following User Says Thank You to JDC For This Useful Post:
globus999 (09-07-2010)
Old 09-07-2010, 01:38 PM   #3
Good luck
Tx!. I get you. Strangely enough, this is the way it was set-up by the builder and... gasp! it passed inspection! OMG!
You are right, I might as well scrap the standpipe and discharge into the sink. Oh.... well...
TX! again.
Removing kitchen sink sprayer - Can't get the locking washer off of the PVC pipe mickapoo Plumbing 17 11-10-2011 09:52 PM
How to plumb laundry sink and washer... bcbud3 Plumbing 13 03-10-2010 10:05 AM
kitchen sink gargles when washer is draining Tonglebeak Plumbing 38 02-24-2010 01:43 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
