Sink Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2013, 05:34 PM   #1
sink vent pipe
I am remodeling my kithen and removing the existing bulkhead si we can install taller cabinets. The sink vent pipe runs up the exterior wall does a 90 in the bulk headand the up to the roof. Is there any raeson I can't run it up through the seal plate (I think that is what is called-the two horizontal 2x4's) and then 90 and up to the roof? The is enough clearance to accomplish that, just not sure it it is okay to drill a hole in the seal plate.
Oscar5 is offline   Reply With Quote
Old 03-27-2013, 05:38 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 358
I typically do drill the top plates but there may be a structural reason why the original plumber didn't.
And it's sill plate- which is at the floor
Old 03-27-2013, 05:49 PM   #3
Rewards Points: 12,886
No such thing as a seal plate, if your talking about a double top plate, drill all you want not going to effect anything.
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 12:48 PM
Distance from vent pipe to clean out? toddmanqa Plumbing 2 03-24-2012 02:41 PM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
Vent pipe - horizontal? secutanudu Plumbing 3 03-02-2011 07:23 PM
Draining a sink into the vent pipe? vseven Plumbing 23 08-20-2010 12:58 AM
