Old 07-31-2010, 10:38 PM   #1
siggy312's Avatar
sink vent
see attached picture - specifically related to the relative position if the vent line. Can I do this ??
siggy312 is offline   Reply With Quote
Old 07-31-2010, 11:41 PM   #2
call me E
TheEplumber's Avatar
sink vent
no, not by the plumbing code I work under. You need to have the vent above the center line of of the horizontal drain. Turn the elbow into a sanitary tee and use the tee's top inlet your vent.
Old 08-01-2010, 01:01 AM   #3
siggy312's Avatar
sink vent
much thanks
another option ( which I do not think is "proper" )
Old 08-01-2010, 09:53 AM   #4
Owner
LateralConcepts's Avatar
sink vent
Looks proper to me.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 08-01-2010, 09:54 AM   #5
Licensed Master Plumber
sink vent
Still wrong. vents must rise vertical to a point 6" above the flood level rim of the highest fixture served before they can run horizontal.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 08-01-2010, 10:02 AM   #6
call me E
sink vent
OK in my neck of the woods, AHJ alows it all the time but it is not the prefered method.
Old 08-01-2010, 10:26 AM   #7
sink vent
No, not under anybody code will that fly. That horizontal bit under the sink can not be horizontal unless it is 6" above the rim of the lav. Any inspector that lets that fly needs to spend more time with his code book and less time at the coffee shop.
Old 08-01-2010, 11:30 AM   #8
siggy312's Avatar
sink vent
thanks to all
I think my "solution" will be to notch out the studs under the window and maintain a 45-60 slope on the vent line (and use some "stud-shoes"). This will ultimately result in the p-trap being 4-6" above the floor of the sink cabinet.
Old 08-01-2010, 11:34 AM   #9
Xtreme DIY'r
sink vent
I had double windows over my sink & extending past each side
Simply wasn't any area to run a vent pipe up & out
In cases like that is it better to:
Not have a vent
Use an AAV
Run to one side & then up ?
Old 08-01-2010, 12:04 PM   #10
sink vent
Increase the size of the stack to 2" if the developed length of the 1 1/2" trap arm is too long to meet code and offset it. I hate AAV's and will ( ok have) fired plumbers who used them. Stack venting is also an option.
Old 08-01-2010, 04:57 PM   #11
sink vent
If you use 2 45s where you have the ells and go 6in above the sink before you go horizontal you will ge o.k.
braindead is offline   Reply With Quote
Old 08-01-2010, 05:58 PM   #12
siggy312's Avatar
sink vent
much thanks to all
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 04:17 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 07:49 PM
Vent stack for kitchen sink stan 41943 Plumbing 19 03-16-2008 06:50 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 06:28 PM
