Old 03-13-2006, 08:55 AM   #1
sink vent?
Is it true that if a bathroom sink is within a certain distance of the sewer drain/vent stack that the sink doesn't need a vent?
If so, then what is the distance?? (3 feet, 5 feet, 7 feet???)
redline is offline   Reply With Quote
Old 03-13-2006, 10:34 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
sink vent?
No that is not true. Every fixture needs a trap and a vent after it.
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-13-2006, 09:36 PM   #3
sink vent?
Are you referring to an Air admittance valve ?
Scott_K is offline   Reply With Quote
Old 03-13-2006, 09:55 PM   #4
Oldguy
Rehabber's Avatar
sink vent?
In Calif the allowed distance is 2 and 1/2 feet.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 03-15-2006, 09:46 AM   #5
sink vent?
Can two fixtures share a common vent? I have a hot tub I want to install in my basement, and there is a utility sink with a vent attached in the basement, going up to the roof. Can I tee off the drain line for the sink with the hot tub drain and use the same vent? Both sink and tub have traps installed. Thanks.
jjksak is offline   Reply With Quote
Old 03-17-2006, 08:05 AM   #6
sink vent?
Mike
what is 'wet' venting?
Old 03-13-2008, 04:32 PM   #7
sink vent?
Please explain air admittance valve concept. Accepted by code?
stan 41943 is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-19-2007 12:26 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
