Old 10-27-2009, 02:56 PM   #1
Default Sink troubles
My bathroom sink is having issues. The faucet is one of those with just the one knob that you push up for water and then twist left for hot and right for cold. Whenever I turn it all the way on and all the way to hot, I get rapid banging sounds and the water will kind of sputter. It sounds like a jack hammer. It only happens with this one sink and only when I turn the water to full pressure and all the way to the right.
I've taken the faucet apart to see if I could tell if there was something in the tubing that might be blocking it but I can't really tell. The sink has long, rigid, copper tubes that have bends in them so I can see up to the bends and up to the bends is clear.
Any ideas?
SAHD is offline   Reply With Quote
Old 10-28-2009, 07:53 AM   #2
What you describe sounds like loose faucet washers, but that faucet does not have washers, just o-rings. Check the aerator and recheck the valve piston.
Old 10-28-2009, 12:05 PM   #3
Sorry, I should have put this in my first post but I am a complete newbie to home repair, especially plumbing. So I don't know what the aerator or the valve pistons are. Everything I know I've learn by Googling it, lol.
More On This Topic
You can easily install a water filter under your sink to clean the water before it leaves a special water faucet. These under sink water filters check for a large variety of harmful contaminates found in tap water, making the under sink water filters... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Hello! My name is Dwayne Carter and on behalf of expertvillage.com, I am here talking about cleaning brass instruments. What I am going to do here is flush the instrument out. From our playing you get tiny particles inside your horn that tends to stick... Read More »
Today we’re installing a kitchen sink in a rebuilt counter. We already have the sink secured with the braces and everything. The next step that we want to do is to actually install the sink supply lines onto the faucet valves. You want to loosen... Read More »
Sink gasping water Filbee Plumbing 7 10-23-2009 12:36 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 07:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 07:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 10:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 08:42 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
