Sink Stack Size ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2013, 10:45 AM   #1
Rewards Points: 140
sink stack size ?
kitchen sink. i have to run it inside an outside wall. to the original roof vent that is very close by. i think i will have to drill the top plate. so i want to keep the hole as small an needed.
Fix'n it is offline   Reply With Quote
Old 06-30-2013, 01:31 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
kitchen sink drain = 2", 2 9/16" bit
kitchen sink vent" 1.5", 1 1/8" bit
Old 06-30-2013, 03:29 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,376
E..... You're good, but I bet ya can't make that work
MTN REMODEL LLC is online now   Reply With Quote
Old 06-30-2013, 03:32 PM   #4
Plumber
Rewards Points: 348
You're right- I fixed the typo- 1.5" pipe takes a 2 1/8" bit
Old 07-01-2013, 09:32 PM   #5
Rewards Points: 140
thanx E
Old 07-02-2013, 06:33 PM   #6
Rewards Points: 1,684
E just greases that pipe up and hammers it through.....
Old 07-02-2013, 06:51 PM   #7
Plumber
Rewards Points: 348
I buy it by the case---
Old 07-13-2013, 10:39 AM   #8
Rewards Points: 140
i just measured my 1 1/2 pipe. looks like 2" would take it easy. am i missing something ?
Old 07-13-2013, 11:11 AM   #9
Rewards Points: 3,130
Could if he has a vent shrinker.
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 09:29 PM
Plumb Washer & Laundry Sink Into Existing Stack hammerlane Plumbing 12 10-26-2011 07:42 AM
Main vent stack moving / resizing / removing (///AG) SFX Group Plumbing 11 11-16-2010 07:47 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
