Sink Problems After Servicing - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-26-2011, 01:38 AM   #1
Sink problems after servicing
Have a quick question, as im stumped on a sink issue. I turned off my shut off valve underneath my sink in order to service a clog. After I was finished I have little to no water pressure, nothing but a tiny stream of water. My shutoff valves for both hot and cold are working, if I turn the shutoff valve to off on the cold side, while the cold water is running, it shuts off, vice versa for hot. Any idea what could cause this?
Thanks!
SeanBaun is offline   Reply With Quote
Old 10-26-2011, 04:53 AM   #2
DIY staff
Rewards Points: 7,174
Remove the aerator on the faucet--and clean it---
If it's a pullout type---unscrew the head and clean the filter-
also--on some pull outs --there is a tiny back flow valve where the hose screws or clip into the valve body---remove that and clean it.
Old 10-26-2011, 06:38 AM   #3
First, what mike said. Then....the washers in older shutoff valves disintegrate over time an can clog the valve or further downstream, such as the aerator. Replace the washers, or replace the valve with a new 1/4 turn ball valve, no washers.
The Following User Says Thank You to Just Bill For This Useful Post:
oh'mike (10-26-2011)
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 03:05 PM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 06:07 PM
Tiling in a Zero-Radius Undermount Sink (How to Seal Properly) yhfwd05 Building & Construction 4 10-04-2009 06:47 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-18-2007 11:26 PM
