Sink Popup Lever - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2013, 07:08 PM   #1
Rewards Points: 1,088
sink popup lever
I had to replace the ball today because I could not raise/lower the stopper. Determined that the ball was cracked. Went to HD and got a replacement lever, but neither the original nut nor the replacement ball/lever had a seal. Initially, I tried the smaller ball, but it leaked. I installed the larger ball, and no leaks. Because there is no seal, and to allow ease of raising/lowering the stop, have people used a dollop of silicone grease/sealant?
handy man88 is offline   Reply With Quote
Old 10-13-2013, 07:27 PM   #2
Rewards Points: 232
I never had to use silicone or grease, they usually come with a ball washer for the opening, and a tapered washer inside the pivot nut. May have already been in there and you just didn't notice it. No grease or silicone required. Well, no leaks, no drips, no errors, so I say you win regardless.
jmon is online now   Reply With Quote
The Following 3 Users Say Thank You to jmon For This Useful Post:
handy man88 (10-13-2013), oh'mike (10-13-2013), plummen (10-13-2013)
Old 10-13-2013, 09:38 PM   #3
When I removed the nut, there was no seal inside the nut. When I removed the ball and felt inside, I cleaned out the rust residue from the lever but didn't feel a seal in particular. I'll keep monitoring, and worse case, will apply some silicon grease if necessary. The last thing I want to do is to replace the entire drain.
The Following User Says Thank You to handy man88 For This Useful Post:
jmon (10-13-2013)
Old 10-13-2013, 09:58 PM   #4
Rewards Points: 232
Apparently the pivot ball is doing a good job. Yea, I hear ya handy man. That's more work and money that doesn't need to be done yet if nothing's leaking.
The Following User Says Thank You to jmon For This Useful Post:
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 01:13 PM
Bathroom sink. Drain pipe cracked from stopper lever. Mathlete Plumbing 11 11-10-2012 03:34 PM
Popup not holding water in sink m1951mm Plumbing 1 08-12-2011 08:04 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Faucet Drain Lever Installation DK75 Plumbing 3 05-21-2008 11:08 AM
