Sink Pop Up Horizontal Bar "ball" Leaks...How Do I Stop? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2009, 07:28 PM   #1
Question
Sink pop up horizontal bar "ball" leaks...How do I stop?
Hi,
I just installed a new pop up pipe for the bathroom sink and all is well except for where the horizontal bar that has the white ball on it.
Water is leaking from that little pipe with the "white ball" inside. I've tried repositioning the entire pipe, but no matter where I put it, the leak still happens.
Any advice on how to stop this is greatly appreciated.
Thank you, in advance, for your assistance.
Robb
prorobb123 is offline   Reply With Quote
Old 05-08-2009, 08:34 PM   #2
The cap that holds the white ball and lever into the pipe has a rubber or plastic seal in it. Make sure it is there and tighten the nut a bit more.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
anti freezing stop and waste valve leaks James Parsons Plumbing 1 10-07-2007 02:11 PM
Cement Utility Sink - Cracks and Leaks amazinlittledevil Plumbing 3 01-25-2007 02:59 PM
