Sink Pop-up Does Not Fit Into Pivot Rod - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2009, 06:10 PM   #1
Sink pop-up does not fit into pivot rod
Hi Folks,
I am totally inexperienced in plumbing, but here goes: my bathroom sink pop-up is not working properly. It either won't seal or it is too tight. I tried adjusting the clevis holes up or down, but still the same problem. The pop-up has a little hook at the bottom that looks like it should hook right into the pivot rod in the sink, but when I shone a bright light down the sink drain, I noticed the pivot rod only goes less than a half inch across the drain. I thought maybe the rod had fallen out of adjustment, but when I undid the retaining nut that holds the pivot rod in place, it looked like the rod was firmly seated (there's a little pivot ball that holds it in place.)
My question: how do I get the pop-up to engage properly with the pivot rod?
Thanks in advance,
Oski
Oski is offline   Reply With Quote
Old 07-25-2009, 06:41 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Rotate the pop-up 180. Some stoppers have an off set to the connection. See if that helps
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
