Sink Piping Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2011, 04:11 PM   #1
Rewards Points: 206
Sink piping question
I would like to know if they make flexible 3/8 pipe like the one in the picture. My faucet moves back and forth and the fittings, with the arrows pointing towards them, keep coming loose and leaking. If they don't make a flexible tubing, is there a better connection system, like those shark bite connectors? Thanks
joeg679 is offline   Reply With Quote
Old 06-05-2011, 04:35 PM   #2
Just call me Andrew
Rewards Points: 1,020
First off, you should fix the faucet so it stops moving.
Second, you can replace those lines with braided stainless steel hoses:
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
joeg679 (06-05-2011)
Old 06-05-2011, 04:44 PM   #3
Rewards Points: 206
Actually, I meant that the faucet moves left and right as it's supposed to, but the plumber who installed it cut that tubing too short and when I rotate it either way, it moves the fittings. I went to Lowes earlier and didn't see that flexible tubing, is there a place online to get it or does HD have it? Thank you.
Old 06-05-2011, 04:45 PM   #4
Just call me Andrew
Not sure what you mean, the fittings shouldn't move.
HD/Lowe's has it....very common. You missed it
Andrew
Old 06-05-2011, 05:10 PM   #5
faucet piping
You have to explain what you mean: " the faucet moves left and right as it is supposed to". Then, you can put the flexible pipe like the one in the picture.
Gabriel24 is offline   Reply With Quote
The Following User Says Thank You to Gabriel24 For This Useful Post:
Old 06-05-2011, 05:13 PM   #6
Rewards Points: 206
The faucet head pivots so I can move it around to reach different areas. The flexible tubing would perfectly. Any idea on pricing?
Old 06-05-2011, 05:49 PM   #7
Rewards Points: 1,596
LIke <$10 each. Your faucet body should not rotate even though you rotate the spout. You or someone needs to tighten the hold-down nut(s) before changing out these lines.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Old 06-05-2011, 05:54 PM   #8
Rewards Points: 206
Ok. Thanks guys. I appreciate all your help.
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 03:05 PM
Adding a utility sink in the basement - draining question sbazzle Plumbing 3 04-24-2010 05:59 PM
Pedestal Sink Plumbing Question Docfletcher Plumbing 1 04-09-2010 05:57 AM
Question about GFCI behind future kitchen sink ChrisDIY Electrical 5 02-18-2010 09:02 AM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
