Sink Pipe Broken - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2013, 07:59 AM   #1
Sink Pipe Broken
As you can see in the attached image, the pipe underneath one side of our kitchen sink is not right (understatement of the day). I am a noob (as in never did any repairs). So please help me determine how to fix this. What do I need to buy? What tools? And any other tips.
Thank you so much.
(Oh I am trying to fix two other major plumbing issues in our house. If you'd like to help me go from noob to in a day, please click on my name and help with these other two repairs. Thanks!!)
septerr is offline   Reply With Quote
Old 01-20-2013, 09:06 AM   #2
Lightfoot's Avatar
Rewards Points: 272
sorry, but i'm not seeing the picture anywhere.
Lightfoot is offline   Reply With Quote
Old 01-20-2013, 10:04 AM   #3
Attached image!
Sorry I had forgotten to attach the image. It is there now. Thanks!
Old 01-20-2013, 10:25 AM   #4
Rewards Points: 13,456
Now back up and take another picture so we can see how the whole thing is run.
Old 01-20-2013, 10:33 AM   #5
The Whole Picture
Here it is!
Old 01-20-2013, 10:42 AM   #6
funfool's Avatar
Rewards Points: 534
Hard to tell from photo, looks like it came loose not broke.
Unscrew the nut from the sink, slide it over the pipe, and will be a plastic bushing or washer that slides over the pipe. As you tighten the nut back down, will put pressure on the bushing and hold it in place. Be sure to clean and wipe everything with a rag, only hand tighten and do not use a wrench.
As you can see, is not much to it, if you bump the pipe to many times or pile to much crap under the sink and put weight on it, it can come loose. Is possible whoever installed it cut it to short and is pulling out.
It is called a kitchen sink drain kit, is $7 at home depot. If you need to replace it.
Will need a hand saw of some sort to cut the pipe to proper length.
My thingy bobber is still broke and cant post photos again
http://www.homedepot.com/catalog/pro...8fb411_300.jpg
funfool is offline   Reply With Quote
Old 01-20-2013, 10:51 AM   #7
funfool's Avatar
Rewards Points: 534
I should have waited for second photo to appear, shows much more.
Still looks like it came loose and may be able to just put it back together.
But what is all the crap around the joints?
To replace it all, is called a double basin kitchen sink drain kit, and you need to be sure you get a tail piece with the dishwasher drain also.
May be a kit with the piece included, or may need to buy it separate.
Old 01-20-2013, 10:56 AM   #8
Thank you. I don't know what the stuff around the joints is, this is how it already was when I moved in here some months ago. I feel tempted to change the whole shebang. I will head to home depot and enquire. Thanks again!!
Tags
sink pipe repair
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
iron vent pipe broken at fitting CCarlson Plumbing 3 02-18-2009 07:40 PM
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 06:23 PM
Broken Drain Pipe - Outside of House - Explative Explative Explative - Leah Frances Plumbing 17 05-09-2008 12:47 AM
