-   -   Sink Pipe Broken (http://www.diychatroom.com/f7/sink-pipe-broken-169593/)
septerr 01-20-2013 07:59 AM
Sink Pipe Broken
1 Attachment(s)
As you can see in the attached image, the pipe underneath one side of our kitchen sink is not right (understatement of the day). I am a noob (as in never did any repairs). So please help me determine how to fix this. What do I need to buy? What tools? And any other tips.
Thank you so much.
(Oh I am trying to fix two other major plumbing issues in our house. If you'd like to help me go from noob to :smartass: in a day, please click on my name and help with these other two repairs. Thanks!!)
Lightfoot 01-20-2013 09:06 AM
sorry, but i'm not seeing the picture anywhere.
septerr 01-20-2013 10:04 AM
Attached image!
Sorry I had forgotten to attach the image. It is there now. Thanks!
joecaption 01-20-2013 10:25 AM
Now back up and take another picture so we can see how the whole thing is run.
septerr 01-20-2013 10:33 AM
The Whole Picture
1 Attachment(s)
Here it is!
funfool 01-20-2013 10:42 AM
Hard to tell from photo, looks like it came loose not broke.
Unscrew the nut from the sink, slide it over the pipe, and will be a plastic bushing or washer that slides over the pipe. As you tighten the nut back down, will put pressure on the bushing and hold it in place. Be sure to clean and wipe everything with a rag, only hand tighten and do not use a wrench.
As you can see, is not much to it, if you bump the pipe to many times or pile to much crap under the sink and put weight on it, it can come loose. Is possible whoever installed it cut it to short and is pulling out.
It is called a kitchen sink drain kit, is $7 at home depot. If you need to replace it.
Will need a hand saw of some sort to cut the pipe to proper length.
My thingy bobber is still broke and cant post photos again :censored:
http://www.homedepot.com/catalog/pro...8fb411_300.jpg
funfool 01-20-2013 10:51 AM
I should have waited for second photo to appear, shows much more.
Still looks like it came loose and may be able to just put it back together.
But what is all the crap around the joints?
To replace it all, is called a double basin kitchen sink drain kit, and you need to be sure you get a tail piece with the dishwasher drain also.
May be a kit with the piece included, or may need to buy it separate.
septerr 01-20-2013 10:56 AM
Thank you. I don't know what the stuff around the joints is, this is how it already was when I moved in here some months ago. I feel tempted to change the whole shebang. I will head to home depot and enquire. Thanks again!!
